I’m trying to use my browser from off-net via the internet to log into remote MTs to link to their hotspot APs as though I were a local hotspot user. I want to see what each hotspot user sees but I am not physically at the MT, I’m across the country.
I have a route and a firewall entry to go from the internet port on ether1 to the gateway on the hotspot, but I’m not getting connected. I don’t get any reply in the browser.
OH!, So you can login to the MT but you can’t get to the AP’s that are connected to the Hotspot interface.
Have you tryed seting up a tunnel?
Do the AP’s have the same IP range as the Hotspot customers or do they have their own IP range?
Are you saying that doing what you did allowed you to use a web browser to log in to the hotspot and get the html login screen? Can you go over the exact settings you used please? Anxiously awaiting the rest of your test.
Yes it did, but I was doing it on 2.8.28 and some people are saying that it won’t work on 2.9.39 so I have to try it on new box to make sure the thing works the same. I will post a howto after that.
Also a guy in DSL reports forum posted this.
Answer from Mikrotik:
The only way how to do it is enable the hotspot on the ether2 and specify one IP to use hotspot and other IPs will be bypassed.
