monitor ip address usage
Is it possible to like see which ips are using the internet.
Say for a simple office setup.
all the computers are on a dhcp and no fancy settings.
Just normal NAt router.
Reason im asking is:
the otherday i was using the net. and i loged into the router and the internet usage was like full.
and i wanted to know who was downlaoding.
So i went into proxy and u can only see the sights under cache.
I was wandering is it possible to like access or code a feature than kinda keeps an eye on each ips throughput ?
Just an idea i had.
Mirror port with Wireshark
Torch
The built in traffic sniffer
Queues show their usage, if they are by IP you can see who is causing traffic
oh thanks,
I cant belive i have never seen that before ???
