Hello, I’m working with php API, my problem is that when I get the data from monitor-traffic these are different from real!
example …
from mikrotik console…
rx-packets-per-second: 315
rx-drops-per-second: 0
rx-errors-per-second: 0
rx-bits-per-second: 368.9kbps
tx-packets-per-second: 369
tx-drops-per-second: 0
tx-errors-per-second: 0
tx-bits-per-second: 3.2Mbps
from API PHP
tx-bits-per-second=3874178
rx-bits-per-second=4106455
My php code
$API = new routeros_api();
$API->debug = false;
if ($API->connect(‘10.10.10.1’, ‘admin’, ‘ADRIAN81’)) {
$API->write(‘/interface/monitor-traffic’);
$API->write(‘=interface=lan’);
$API->write(‘=once=’);
$ARRAY = $API->read(false);
print_r($ARRAY);
$API->disconnect();
thanks for your help!
