Hello everyone,
I’m currently looking for a solution to monitor the BGP states of my Mikrotik devices (CHR), and I haven’t found any available OID for this.
Therefore, I’m looking for advice and tips to closely monitor this important information.
Has anyone successfully monitored the BGP states of their Mikrotik devices ? If so, how did you do it?
I’m open to all possible solutions, whether they involve custom scripts, third-party tools, or any other means.
I know some topics are already open to that, but i haven’t find any viable solutions yet.
Thank you in advance for your help and contributions on this topic.
Yochiro
2dfx
April 25, 2023, 10:53am
4
Hi!
BGP state by mail:
# EDIT HERE
:local arrEmails [:toarray "EMAIL1@TEST.CORP,EMAIL2@TEST.CORP"];
:local debug false
# EDIT END
# Define Variables
:global arrBgpState;
:global gotKey false;
:local hostNameX ([/system identity get name]);
:local statusX;
:local peerX;
:local peerXarrEl;
:local mailToX;
:local mailSubjectX;
:local mailBodyX;
:local peerStatusX;
:local arrBgpPeers [:toarray ""];
:local peername "";
:local peerTotal "";
if ($debug = true) do={
:log info ("=============BGP PEER STATUS DETECTION STARTED=============" )
# Initialize global array - kinda lame way to do it :P
:if ( [:len $arrBgpState] =0 ) do={
:set $arrBgpState {"false"="false"}
# Fill arrBgpPeers array with peers name
:foreach i in=[/routing bgp peer find] do={
:set peername [/routing bgp peer get $i name];
:set peerTotal ($peerTotal . "," .$peername);
:set arrBgpPeers [:toarray $peerTotal];
# Loop through the peers array
:local arrPos
:for arrPos from=0 to=([:len $arrBgpPeers]-1) do={
# Set peerX to current peer name for this iteration
:set peerX [:pick $arrBgpPeers $arrPos];
# Check if peer is enabled and proceed
:if ([/routing bgp peer get [find name=$peerX] disabled ] != true) do={
# Get Peer Status
:set peerStatusX [/routing bgp peer get [find name="$peerX"] state]
# Find peer key in global array
:foreach k,v in=$arrBgpState do={
if ($k != "false") do={
:if ($gotKey = false) do={
:if ($k = $peerX) do={
:set gotKey true
# Initialize arrBgpState array element with peerX name if it doesn't already exist
:set ($arrBgpState->"$peerX") "up"
# Reset this for the next iteration
:set gotKey false
# Previous run peer status
:set statusX ($arrBgpState->"$peerX")
# Prepare Email body
:set mailBodyX ("Router Hostname: " . $hostNameX . "\nBGP Peer Status: " . $peerStatusX . "\nBGP Peer Name: " . $peerX . "\n");
# Check if BGP Peer is not established
:if ($peerStatusX != "established") do={
# Check if this is the first time the peer is doen
:if ( $statusX = "up" ) do={
# Set value to 'down' to peer global var key
:set ($arrBgpState->$peerX) "down"
# Informational Log
:log error ("BGP Peer ". $peerX ." state is " . $peerStatusX . ". Sending email alerts!" )
# Prepare Email subject
:set mailSubjectX ("BGP Peer ". $peerX ." on ". $hostNameX . " is NOT established!");
# Loop over emails array to send emails to all recipients in array
:local arrPos2
:for arrPos2 from=0 to=([:len $arrEmails]-1) do={
# Set mailToX to recipient for this iteration
:set mailToX [:pick $arrEmails $arrPos2]
# Informational Log
:log error ("BGP Peer " . $peerX . " status is " .$peerStatusX. "! Sending Email alert to " . $mailToX . "." )
# Send Email
/tool e-mail send to=$mailToX subject=$mailSubjectX body=$mailBodyX;
} else={
# Peer down. Already sent notification so do nothing.
:log info ("BGP Peer ". $peerX ." is already down. Ignoring!")
} else={
# Check if peer just came back up and send informational email
if ($statusX = "down") do={
:set mailSubjectX ("BGP Peer ". $peerX ." on ". $hostNameX . " has recovered!");
:local arrPos2
# Set mailToX to recepient for this iteration
# Informational Log
:log warning ("BGP Peer " . $peerX . " status has recovered! Sending informational Email to " . $mailToX . "." )
# Send Email
:log info ("BGP Peer " . $peerX . " is up. Nothing to do!")
# Set peer status to up
:set ($arrBgpState->$peerX) "up"
} else={
:log warning ("BGP Peer " . $peerX . " is disabled. Ignoring!")
:log info ("=============BGP PEER STATUS DETECTION ENDED===============" )
