Monitoring ethernet speed on RB
Hello.
Can somebody help me with advice on how to monitor ethernet rate (speed) on a routerboard?
Thank you.
It should be either 10, 100, or 1000. Look in the interface section of winbox and you can see what it is using there.
I am sorry. I think I did not make myself clear. I need to monitor it remotely so I can get an alarm if it drops from 100 to 10, for example.
I am using Nagios.
Do a snmpwalk to find the value then make a probe for your monitoring system.
Works for us with the Dude.
Can you please be a little more specific? What exactly should I do?
I’ve no experience with nagios. Look for snmp.
Gesendet von meinem GT-N7000 mit Tapatalk
