Hi
I’m currently monitoring the responses received by my CCR1009 (v6.32.2) router from a remote device
I set up two rules, one filter to simply log incoming packets and a second to dstNAT the incoming packet toward a local server.
add chain=forward dst-port=50013 log=yes log-prefix=QoS-2 protocol=udp \
src-address=213.XXX.XXX.XXX
add action=dst-nat chain=dstnat dst-port=50013 log=yes protocol=udp \
src-address=213.XXX.XXX.XXX to-addresses=192.168.XXX.13 to-ports=50013
The first rule is currently at 11000 packets and the second at 23 !
I don’t understand the origin of this discrepancy; shouldn’t the two rules handle an equal amount of packets ?
I even created a prerouting mangle rule to log these incoming packets:
/ip firewall mangle
add action=log chain=prerouting dst-port=50013 log=yes log-prefix=QoS-2.1 \
protocol=udp src-address=213.XXX.XXX.XXX
Again this shows numerous incoming packets from the remote host
When I look at the logged packets I see the following:
Jan 21 11:57:20 ROUTER QoS-2.1 prerouting: in:ether1 out:(none), src-mac 00:XX:XX:XX:XX:2b, proto UDP, 213.XXX.XXX.XXX:3586->94.XXX.XXX.XXX:50013, NAT 213.XXX.XXX.XXX:3586->(94.XXX.XXX.XXX:50013->192.168.XXX.13:50013), len 200
If I disable the dstNAT rule I obtain the following:
Jan 21 12:01:46 ROUTER QoS-2.1 prerouting: in:ether1 out:(none), src-mac 00:XX:XX:XX:XX:2b, proto UDP, 213.XXX.XXX.XXX:3615->94.XXX.XXX.XXX:50013, len 200
Any ideas ?
thanks
yann
