Monitoring Network Shares
Is it possible in the dude, to check if a network share \Server\Sharename is available.
You can monitor the specific server and specific port. Create new probe, but you need to put correct strings to Send/Receive to get the information you are interesting in.
Its an server with several drives mounted, and sporadically (not often) a drive fails to mount after the restart at night. This means the port probe is not the right way, the port and service is up, then the other drive mounted allright and available. To check the availability I have to check the shares on the drive, or the other way is to check about the availability of a test file.
Is there any way to make this ?
Excuse my english.
Perhaps any other Dude expert can help you with this question, but I’m not sure it is possible to create probe, which monitor specific disk share.
