I think the issue is “may share these data types with third parties”. When you use an app, which is built using all kinds of external libraries and modules, the app developer usually does not know what is happening and just has to assume that all info you see in the app is also visible to all developers/owners of all stuff they use. Hence the disclaimer.
It's assumed that this privacy-conscious person:
Didn't read the privacy policy when they first turned on their phone,
or that they have a self-built phone with their own software development,
uses a self-compiled browser, removing "everything" they don't need,
uses a self-compiled operating system, where they also removed everything.
Just using a SIM card provides a more or less approximate location, and certainly when they connect to the internet, everything they do is already recorded...
And I'd really like to see out of curiosity what DNS applications "use"...
Yes all true, but there is a big difference between “your ISP knows exactly where you are” and “your ISP has built an app, searching the internet for all kinds of modules and libraries made by nerds in their cellar, and the data will be shared with them”.
It isn’t always going to happen, but it might happen, and it is safer for the app developer to just put a disclaimer that it could happen than to later be defending themselves in court.
Yes, of course, but where do you put the os and the apps themselves that are installed by default on your smartphone??? ![]()
Those are a constant source of information to third parties... As soon as you buy it...
And often you can't even remove them...
This is not about the problem for the users, it is about the problem for the ISP (app developer and publisher).
They inform their users that their data may be shared with anyone, and they are covered.
I understand
, but I hope you also understand my point.
Usually this kind of disclaimer is when Firebase or some similar analytics platform is used by app, yet such analytics can be used internally by ISP for other services where also private data is shared with third parties and such disclaimer should be as part of contract.
These infos ISP already have from you unless you are using someone else subscription or you are using anonymously purchased prepaid SIM (some countries it us still possible to purchase, but data plan is usually low).
We use Internet based on a B2B contract that does not contain the personal data of the individuals who use it.
AKA Replicant OS.
DNSCrypt, Tor
The SIM card used for the data-only plan, related to the current thread, is for a fixed location, in an ATL. That has nothing to do with any phones.
Once again: Please kindly let's stay on topic.
Why don't you write it to everyone?
I don't think I'm the only one who's commented about it.
