More 1 line in Script
Hello!
I have the 3-lines script:
/ip route set [/ip route find dst-address=“0.0.0.0/0”] gateway=“xxx.xxx.xxx.xxx”
/routing bgp peer set [/routing bgp peer find name=“ISP1”] out-filter=“”
/routing bgp peer set [/routing bgp peer find name=“ISP2”] out-filter=“OUT_OFF”
I entered it via Winbox in System-Scripts
When I run the script only first line is executed. Other lines are not worked.
I use “;” and different NEWLINES as wrote in manual but in all cases only first line of my script is executed.
Why?
Open and close brackets before and after the commands
/ip route set [/ip route find dst-address="0.0.0.0/0"] gateway="xxx.xxx.xxx.xxx";
/routing bgp peer set [/routing bgp peer find name="ISP1"] out-filter="";
/routing bgp peer set [/routing bgp peer find name="ISP2"] out-filter="OUT_OFF";
The braces are not required, they are optional.
Try this code:
:put ("start script")
:put ("exec: /ip route set")
:put ("exec: /routing bgp peer set for ISP1")
:put ("exec: /routing bgp peer set for ISP2")
:put ("end script")
The output should be:
start script
exec: /ip route set
end script
This means all commands are getting executed. Most likely, all lines are getting executed, but the embedded find commands are failing to find entries.
OK. I have found the trouble.
I have 3 routes in route tables - one of them is static, other are got dynamically from BGP neighbors.
When the first line is executed - the error (or warning) about cannot modify dynamic routes is appeared. After this error (or warning) execution of full script stopped.
I inserted comment “default” and now RouterOS find the right only one route throw comment field.
Thank you for helping!!!
