Does Mikrotik have any plans to produce a 2x2, preferably 3x3 dual band(2.4/5ghz) access point with 802.3at/af support? I love my rb951g unit, but would like to be able to add an 802.11ac unit to the home and ceiling mount it with POE.
EDIT: I happened to run across the StationBox InSpot which will fit the RB922 board. I’m considering pairing that enclosure with the NetMetal 5 3x3 AC unit and sticking in 2x2 2.4ghz addon. The only thing I’m missing is proper POE/POE+ support.
I guess I’m wondering if Mikrotik plans on putting out an RB922 board with POE/POE+ support. Or other 802.11ac boards with 2x2 or 3x3 chains with POE/POE+ support.
