Hi @sindy,
I would like to thank you very much for your support. As I said previously, there were such a lot of garbage in my configuration, because I tried the example of the other guy (the link I put on my first post). Therefore I was very confused and I couldn’t get what you suggested, because your suggestion was most probably based on interfaces that were not mine.
For this reason, I would kindly ask you to check again my request, based on the below configuration and let me know what is needed to be done.
# nov/29/2022 23:30:08 by RouterOS 7.6
# software id = EKRJ-1W8Q
# model = CCR1016-12S-1S+
# serial number = XXXXXXXXXXX
add arp=proxy-arp name=LAN-Bridge
set [ find default-name=sfp1 ] name="sfp1 (WAN)"
set [ find default-name=sfp2 ] disabled=yes name="sfp2 (WAN-LTE)"
set [ find default-name=sfp3 ] name="sfp3 (LAN1)"
set [ find default-name=sfp4 ] name="sfp4 (LAN2)"
set [ find default-name=sfp5 ] name="sfp5 (LAN3)"
set [ find default-name=sfp6 ] name="sfp6 (LAN4)"
set [ find default-name=sfp12 ] name="sfp12 (Management)"
/interface pppoe-client
add add-default-route=yes disabled=no interface="sfp1 (WAN)" name=\
MK-XXXXXXXXXXX user=XXXXXXXXXXX@XXXX.XX
/interface wireguard
add listen-port=51922 mtu=1420 name=wireguard-XXX-XX
/interface vlan
add interface=LAN-Bridge name=vlan1 vlan-id=1
add interface=LAN-Bridge name=vlan4 vlan-id=4
add name=LAN
add name=WAN
/interface lte apn
add comment="Subnet 192.168.1.0/24" name=dhcp ranges=\
192.168.1.120-192.168.1.239
add comment="Subnet 192.168.2.0/24" name=WLAN-GUEST-DCHP ranges=\
192.168.2.10-192.168.2.250
add comment="Subnet 192.168.5.0/24 (VPN)" name=VPN-Pool ranges=\
192.168.5.2-192.168.5.250
add name=vl16 ranges=192.168.16.10-192.168.16.249
add address-pool=dhcp interface=LAN-Bridge name=192.168.1.120-239
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add dns-server=192.168.1.2 local-address=192.168.5.1 name=VPN remote-address=\
VPN-Pool
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=LAN-Bridge interface="sfp3 (LAN1)"
add bridge=LAN-Bridge interface="sfp4 (LAN2)"
add bridge=LAN-Bridge interface="sfp5 (LAN3)"
add bridge=LAN-Bridge interface="sfp6 (LAN4)"
add bridge=LAN-Bridge interface=vlan1
add bridge=LAN-Bridge interface=vlan4 pvid=4
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=LAN-Bridge tagged=\
"LAN-Bridge,sfp3 (LAN1),sfp4 (LAN2),sfp5 (LAN3),sfp6 (LAN4)" vlan-ids=4
add bridge=LAN-Bridge vlan-ids=1
add interface=LAN-Bridge list=LAN
add interface="sfp1 (WAN)" list=WAN
add interface=MK-XXXXXXXXXXX list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface sstp-server server
set authentication=mschap2 certificate=XXX-XX-FW01 default-profile=VPN pfs=\
yes
/interface wireguard peers
add allowed-address=192.168.5.2/32 comment="0001 (Angelos Pitsos)" interface=\
wireguard-XXX-XX public-key=\
"XXXXXXXX"
add allowed-address=192.168.5.253/32 comment="0252 (Test01)" interface=\
"XXXXXXXX"
add allowed-address=192.168.5.3/32 comment="0002 (Raffaela Steiner)" \
interface=wireguard-XXX-XX public-key=\
"XXXXXXXX"
add address=192.168.178.22/24 comment=WAN-LTE interface="sfp2 (WAN-LTE)" \
network=192.168.178.0
add address=192.168.90.1/24 comment=Management interface="sfp12 (Management)" \
network=192.168.90.0
add address=192.168.1.24/24 comment=LAN interface=LAN-Bridge network=\
192.168.1.0
add address=192.168.2.1/24 interface=*11 network=192.168.2.0
add address=192.168.5.1/24 comment=VPN disabled=yes interface=LAN-Bridge \
network=192.168.5.0
add address=192.168.5.1/24 interface=wireguard-XXX-XX network=192.168.5.0
add address=192.168.16.1/24 interface=vlan4 network=192.168.16.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add interface="sfp2 (WAN-LTE)"
add interface=sfpplus1
add address-pool=WLAN-GUEST-DCHP interface=*11 name=192.168.2.0/24
/ip dhcp-server lease
add address=192.168.1.220 client-id=1:90:9:d0:18:bb:29 mac-address=\
XX:XX:XX:XX:XX:XX server=192.168.1.120-239
add address=192.168.1.230 client-id=1:90:9:d0:18:bb:34 mac-address=\
add address=192.168.1.0/24 dns-server=192.168.1.2 domain=xxxxxxx.local \
gateway=192.168.1.24 wins-server=192.168.1.2
add address=192.168.2.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.2.1
set servers=1.1.1.1,8.8.8.8
/ip firewall address-list
add address=hq.planettechnologies.eu list=Authorized_IPs
add address=192.168.1.0/24 list=Internal_Networks
add address=192.168.2.0/24 list=Internal_Networks
add action=accept chain=input comment="Allow established connections" \
connection-state=established
add action=accept chain=input comment="Allow related connections" \
connection-state=related
add action=drop chain=input comment="Drop invalid connections" \
connection-state=invalid
add action=accept chain=input comment="Allow limited pings" limit=\
50/5s,2:packet protocol=icmp
add action=drop chain=input comment="Drop excess pings" protocol=icmp
"Access WebFig & WinBox Management interface" dst-address=192.168.90.1 \
dst-port=80,443,8291 protocol=tcp
"Access WebFig & WinBox LAN interface list" dst-address=192.168.1.24 \
"Access Webfig & WinBox on any interface from Authorized IPs" dst-port=\
80,443,8291 protocol=tcp src-address-list=Authorized_IPs
add action=accept chain=input comment="Access SSTP connections from WAN" \
dst-port=443 log=yes log-prefix=SSTP-Input protocol=tcp
add action=accept chain=input comment="Custom SSH port for secure shell" \
dst-address=192.168.1.24 dst-port=2202 protocol=tcp
add action=accept chain=input comment="Allow local loopback (for CAPsMAN)" \
dst-address=127.0.0.1
add action=accept chain=input comment="Access Wireguard VPN" dst-port=51922 \
in-interface-list=WAN protocol=udp
add action=drop chain=input comment="Block DNS request from WAN" dst-port=53 \
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="Drop any TCP port left OPEN" protocol=\
tcp
add action=drop chain=input comment="Drop any UDP port left OPEN" protocol=\
udp
add action=drop chain=input comment="Drop all not coming from LAN" \
in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment=fasttrack \
add action=accept chain=forward comment="Allow established connections" \
add action=accept chain=forward comment="Allow related connections" \
add action=accept chain=forward comment="Allow all inbound traffic from VPN su\
bnet (192.168.5.0/24) to LAN-Bridge (192.168.1.0/24)" disabled=yes \
dst-address=192.168.1.0/24 src-address=192.168.5.0/24
add action=accept chain=forward comment="Allow all inbound traffic from LAN-Br\
idge (192.168.1.0/24) to VPN subnet (192.168.5.0/24)" disabled=yes \
dst-address=192.168.5.0/24 src-address=192.168.1.0/24
add action=drop chain=forward comment="Drop invalid connections" \
connection-state=invalid log=yes log-prefix=Drop-invalid-Input
add action=drop chain=forward comment="Block Bogon IP Addresses" src-address=\
0.0.0.0/8
add action=drop chain=forward dst-address=0.0.0.0/8
add action=drop chain=forward src-address=127.0.0.0/8
add action=drop chain=forward dst-address=127.0.0.0/8
add action=drop chain=forward src-address=224.0.0.0/3
add action=drop chain=forward dst-address=224.0.0.0/3
add action=accept chain=forward comment="Allow limited pings" limit=\
add action=drop chain=forward comment="Drop excess pings" protocol=icmp
"Allow subnet 192.168.1.0/24 Web Surfing (HTTP & HTTPS)" dst-address=\
0.0.0.0/0 dst-port=80,443 protocol=tcp src-address-list=Internal_Networks
"Allow subnet 192.168.1.0/24 DNS & NTP (TCP)" dst-address=0.0.0.0/0 \
dst-port=53,123 protocol=tcp src-address-list=Internal_Networks
"Allow subnet 192.168.1.0/24 DNS & NTP (UDP)" dst-address=0.0.0.0/0 \
dst-port=53,123 protocol=udp src-address-list=Internal_Networks
"Allow subnet 192.168.1.0/24 Email communication" dst-address=0.0.0.0/0 \
dst-port=465,587,25,993,995,110,143 protocol=tcp src-address=\
192.168.1.0/24
add action=accept chain=forward dst-address=0.0.0.0/0 dst-port=25 protocol=\
udp src-address=192.168.1.0/24
add action=accept chain=forward comment="Allow FTP connections" dst-address=\
0.0.0.0/0 dst-port=20,21,990,6000-6100 protocol=tcp src-address=\
192.168.1.0/24
"Allow 3CX SBC communicating with our hosted 3CX PBX" dst-address=\
XXX.XXX.XXX.XXX dst-port=5090,5001 protocol=tcp
add action=accept chain=forward dst-address=XXX.XXX.XXX.XXX dst-port=5090 \
protocol=udp
"Allow 3CX Web Clients communicating with our hosted 3CX PBX" \
dst-address=XXX.XXX.XXX.XXX dst-port=9000-10999 protocol=udp
add action=accept chain=forward comment="Allow 3CX Tunnels" dst-port=\
add action=accept chain=forward dst-port=5090 protocol=udp
add action=accept chain=forward comment="Allow Speedtest" dst-port=8080 \
protocol=tcp src-address=192.168.1.0/24
add action=accept chain=forward comment="Allow HBCI chip card" dst-port=3000 \
add action=accept chain=forward comment="Allow WhatsApp calls" dst-port=\
5222,5223 log-prefix=WhatApp-Calls protocol=tcp src-address=\
192.168.1.0/24
add action=accept chain=forward dst-port=3478 log-prefix=WhatApp-Calls \
protocol=udp src-address=192.168.1.0/24
add action=accept chain=forward comment="Allow Wi-Fi calling" dst-port=\
500,4500,16384-49327 log-prefix=WiFi-Calling protocol=udp
add action=accept chain=forward comment="Allow custom RDP for Angelos" \
dst-port=25581 protocol=tcp src-address=192.168.1.0/24
add action=drop chain=forward comment="Drop all outbound traffic" \
dst-address=0.0.0.0/0 log-prefix=Drop-All-Outbound src-address=\
192.168.1.0/24
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat comment="VPN with Road Warriors" disabled=yes \
add action=accept chain=dstnat comment="VPN with Road Warriors" disabled=yes \
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
192.168.1.0/24 src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="masquerade for 192.168.1.0/24" \
ipsec-policy=out,none out-interface=MK-XXXXXXXXXXX src-address=\
192.168.1.0/24
add action=masquerade chain=srcnat comment="masquerade for 192.168.2.0/24" \
192.168.2.0/24
add action=masquerade chain=srcnat comment="masquerade for 192.168.3.0/24" \
192.168.3.0/24
add action=masquerade chain=srcnat comment="masquerade for 192.168.4.0/24" \
192.168.4.0/24
add action=masquerade chain=srcnat comment="masquerade for 192.168.5.0/24" \
ipsec-policy=out,none src-address=192.168.5.0/24
add action=masquerade chain=srcnat comment="masquerade for all networks" \
add action=masquerade chain=srcnat disabled=yes out-interface=\
"sfp2 (WAN-LTE)"
add action=netmap chain=dstnat dst-address=192.168.1.0/24 src-address=\
192.168.5.0/24 to-addresses=192.168.1.0/24
add action=dst-nat chain=dstnat comment=\
"RDP_PC-IT-Werkstatt from Authorized_IPs" dst-port=34350 in-interface=\
MK-XXXXXXXXXXX log=yes log-prefix=RDP_PC-IT-Werkstatt_Public protocol=tcp \
src-address-list=Authorized_IPs to-addresses=192.168.1.166 to-ports=3389
add action=dst-nat chain=dstnat comment="RDP_XXX-XX-HV02 from Authorized_IPs" \
dst-port=34351 in-interface=MK-XXXXXXXXXXX log=yes log-prefix=\
RDP_XXX-XX-HV02 protocol=tcp src-address-list=Authorized_IPs \
to-addresses=192.168.1.5 to-ports=3389
add action=dst-nat chain=dstnat comment=ownCloud dst-address=85.220.191.10 \
dst-port=80 log=yes log-prefix=ownCloud protocol=tcp to-addresses=\
192.168.1.237 to-ports=80
dst-port=443 log=yes log-prefix=ownCloud protocol=tcp to-addresses=\
192.168.1.237 to-ports=443
add action=dst-nat chain=dstnat comment="SSH to ownCloud" dst-port=2202 \
in-interface-list=WAN log=yes log-prefix=ownCloud protocol=tcp \
to-addresses=192.168.1.237 to-ports=22
add comment="WAN (LTE)" disabled=yes distance=2 dst-address=0.0.0.0/0 \
gateway=192.168.178.1 routing-table=main suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=2202
/lcd
set backlight-timeout=never default-screen=stats
/lcd interface
set sfpplus1 disabled=yes
set sfp7 disabled=yes
set sfp8 disabled=yes
set sfp9 disabled=yes
set sfp10 disabled=yes
set sfp11 disabled=yes
/ppp secret
add disabled=yes name=apitsos profile=VPN service=sstp
add disabled=yes name=test01 profile=VPN service=sstp
/system clock
/system identity
set name=XXX-XX-FW01
/system ntp client
set enabled=yes
/system ntp client servers
add address=de.pool.ntp.org
But please note that I am getting now a red entry in DHCP server. Not sure why that happened. It wasn’t like that before.
Thank you very much in advance for your time. It is much appreciated.
With kind regards,
Angelos Pitsos
