More MikroTIk HowTo's
I have posted a few MikroTik HowTo’s on my blog:
RoMON
http://stevedischer.com/mikrotik-romon-feature-added-to-routeros/
Another Way to do Automatic Failover with MikroTik RouterOS
http://stevedischer.com/another-way-to-do-automatic-failover-with-mikrotik-routeros/
Improve MikroTik CAPsMAN Roaming Performance
http://stevedischer.com/improve-mikrotik-capsman-roaming-performance/
DHCP Option 43 on MikroTik
http://stevedischer.com/dhcp-option-43-mikrotik-routeros-ruckus/
MikroTik Wireless CAPsMAN Howto
http://stevedischer.com/mikrotik-wireless-capsman-howto/
I hope you find them useful. Good luck!
Steve Discher
http://ISPSupplies.com
http://LearnMikroTik.com
Thankyou Steve for sharing.
A revision for your RoMON how-to
“RouterOS since version 6.38” should be v6.28?
Hi Steve
I can not enter you blog getting “Connection timed out”.
Bigfoot
found a few typos
MikroTik RoMON Feature Added to RouterOS
“I have sen some instability”
These are the ones I talked to you about a few weeks ago.
“Please not you must set up your email server IP,”
This confuses me, I think you mean you set Provider1.
“When pings return, it sets the distance on the default route through PROVIDER2 back to 1 making it the active route”
