My LAN:
192.168.0.1/24
192.168.1.1/24 / Me
192.168.2.1/24 / NAS etc.
I have attached remote drives on the NAS, etc. On the 2.x, everything works, at the moment when you connect to the remote L2TP so it falls, because the subnet is routing over the VPN, not via the LAN, how to say MK to address-list not route through VPN?
The easiest solution is to use another IP range for VPN endpoints (e.g. 192.168.3.x/24)
If you want to use IPs from 192.168.1.x as VPN endpoints, then you need to set the arp type to proxy-arp on the 192.168.1.x interface so that the VPN endpoints can appear to be directly connected to that LAN.
C:\Users\>tracert 192.168.2.2
Tracing route to NAS [192.168.2.2]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms router [192.168.1.1]
2 <1 ms <1 ms <1 ms NAS [192.168.2.2]
with VPN
Tracing route to 192.168.2.2 over a maximum of 30 hops
1 5 ms 6 ms 8 ms 10.75.3.1
I know that can disable default gateway on client side.. But is possible on router side?
