But I am running the pppoe server on an RB433AH with level 5 licence…So will I still be limited to 10 sessions because I use an RB133c for the userman??
yes, this limit is for the user manager, so it doesn’t matter what license you have on your pppoe server, as long as you use a user manager system for it.
by the way, rb133c is not the right machine for User Manager. you should get a serious device for a RADIUS
Yeah I know I need to upgrade…I went to the basic training so I had the 133c lying around so I might as well of used it…My core router is a RB433AH…I was under the impression that usermanager cannot be on the same router as the pppoe server so thats why I am using both routers…
Is it possible to run them both from the same routerboard?
We’ve been considering moving to UM. I want to be sure that I have this correct…
What dictates the maximum number of sessions?
-The License Level of the device running User Manager?
-The License Level of the device making the inquiry to the UM data base?
Example, lets say that we have the following situation, a small WISP with the following devices deployed:
User Manager running on a suitable Level 6 licensed device. (Unlimited UM sessions)
An AP running level 4, serving 50 customers.
Another AP running level 4, serving 50 customers
And another AP running level 4, serving 50 customers.
I imagined that with UM running on the level 6 device that our number of UM users and sessions would be unlimited. Each AP would be unlimited (by UM) in the number of UM controlled connections/sessions that it could handle.
Or, does the license level of each AP have some significance to the number of allowed UM users?
