[admin@MikroTik] > ip dns set
allow-remote-requests cache-max-ttl cache-size primary-dns secondary-dns
So I need more than primary and secondary dns. It is possible?
No, only two dns servers are possible.
Probably you can change primary,secondary dns configuration with scripts.
The most efficient solution to use stable DNS server as ‘primary-server’ in dns configuration.
Ok, thanks. Than I will use netwatch to controll gateways and set dns servers.
