Is it possible to create more than 2 SSIDs per band when using CAPsMAN? For example:
- SSID_1, 2.4 GHz, guest network;
- SSID_2, 2.4 GHz, private network;
- SSID_3, 2.4 GHz, private network for MikroTik wireless clients in station-bridge mode only.
You can create virtual SSIDs but you cant connect a Station Bridge Mode to a Capsman AP…
You should use Station mode instead…
