More then 4 Wan Load Balancing in RB750GL
Dear All I have RB750GL I want to know how we can load balancing more then 4 Wan
I would say that there are not enough ports for that.
Sent from Android by Tapatalk.
Not enough physical ports. But if you were reffereing to WAN as default gateways over e.g. EOIP, VPN, etc. then the answer is yes!
Sir i have 6 ADSL link of 4mb each kindly explain me how can i loadbalance in any method
The simplest way to do this is to use another (1gbit?) 8-port switch and plug it into rb750. Connect all ADSL modems to the switch and create a separate pppoe connection in Mikrotik for each ADSL link. Remove “add default route” and add default routes manually for each pppoe connection with different metrics.
Can spare one device and electricity if 8-port router is used directly. Then the mentioned switch is not needed.
He said he wanted to use 750GL. A 15€ switch is still much cheaper then 8-port or more Mikrotik device.
Thanks for your reply dear. i m trying to explain my scenario that i have 6 ADSL modem F@st 2704 http://www.sagemcom.com/EN/products/communications/broadband-access/broadband-access/sagemcom-fst-2704.html
which providing LAN connection on RJ-45 which I’ll connect in 8 port switch, my question is that we use pppoe for WAN,
how can i configure pppoe between mikrotik and f@st 2704,
Kindly explain with thanks.
