more vlan trunks on CRS125 ?
I followed https://wiki.mikrotik.com/wiki/Manual:CRS1xx/2xx_series_switches_examples , expecially inter-vlan routing
On my CRS125 ports 1-21-22 are trunks carrying tagged vlans to three switches , ports 23 and 24 are WANs, the remaining ports (2 to 20) are members of VLAN10 untagged.
As per wiki I started binding all ports but wans to bridge1, despite they are tagged or not
add name=bridge1 igmp-snooping=no  protocol-mode=none
add bridge=bridge1 interface=ether1 hw=yes
add bridge=bridge1 interface=ether22 hw=yes
I set vlan tagging on cpu port for inter-vlan routing:
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=10
add tagged-ports=switch1-cpu vlan-id=20
add tagged-ports=switch1-cpu vlan-id=30
I added ingress vlan translation for access ports (2 to 20):
/interface ethernet switch ingress-vlan-translation
add ports=ether2 customer-vid=0 new-customer-vid=10 sa-learning=yes
add ports=ether20 customer-vid=0 new-customer-vid=10 sa-learning=yes
Now comes the problem :
Wiki says:
For routing add VLAN interfaces on master-port because it connects with CPU port and add IP addresses to created VLAN interfaces.
/interface vlan
add name=vlan200 interface=ether2 vlan-id=200
add name=vlan300 interface=ether2 vlan-id=300
add name=vlan400 interface=ether2 vlan-id=400
But master-port is no more present from 6.41 on (ether2 in wiki example), should I use bridge created before ???
Next , as I need ports 1, 21 and 22 as vlan trunks to respective switches , where should I declare they are tagged vlan and relative membership ??
Thank you for any help.
It seems you found an imperfection in the Wiki guide.
Before 6.41 you should have created the VLAN interface on top of the master-port interface, but after 6.41 the VLAN interface should be created on top of the bridge interface.
This is actually a common mistake that has been studied here:
https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#VLAN_interface_on_a_slave_interface
Wiki has been updated, thank you for pointing this out!
Thank you for link
In wiki , switch1-cpu port is added to /interface ethernet switch egress-vlan-tag in each desired vlan
Should I do the same for all ethernet ports intended to be vlan trunks carrying tagged vlans to other switches ?
Should those ethernet ports be added to bridge anyway ?
All ports that are involved into switching MUST be added to a bridge.
Trunk ports must be specified in /interface ethernet switch egress-vlan-tag:
add tagged-ports=ether1,ether21,ether22,switch1-cpu vlan-id=10
add tagged-ports=ether1,ether21,ether22,switch1-cpu vlan-id=20
add tagged-ports=ether1,ether21,ether22,switch1-cpu vlan-id=30
Thank you Artz,
One thing is not clear to me from that wiki, look at “Port based VLAN” and “InterVLAN Routing” examples:
The bridge, the ingress-vlan-translation and the egress-vlan-tag are the same.
They differ in Vlan membership declaration.
Port based VLAN uses “/interface ethernet switch vlan”
Inter VLAN Routing uses “/interface vlan”
Why is this ?
Because Inter VLAN need to assign an IP address to vlan interface ? so /interface ethernet switch vlan , is not really an interface ?
