I have a Motherboard 433 with 52N and only I have obtained 65-H Mbps/65-H Mpbs. Not as 130 Mbps obtains
do you have good signal and CCQ? do you have traffic running that can use so much? if there is not enough traffic, the rates will not show maximum
Thaks for your pronts reply.
The CCQ is 90/85%.
Your do you say that if I give him a lot of traffic it can raise the speed?
The troughput that gives me is of 56000 more or less.
