Mounting 2 Omni antenna on mast
Hello
i was planning to put one 2.4Ghz and one 5.8Ghz omni on a mast and just wanted to know does it matter which one should be installed on top and which one bellow the other
In theory no matter who is above and who is below.
In practice I would suggest that 5.8 ghz antenna to be placed on top.
Of course this is also depending on their radiation in the vertical plane and each antenna gain,
When using omni antennas the clients should be in the same height like Ap with omni antenna. So, place them according that taking into account their vertical radiation angle.
as per my calculation if it has 3deg radiation then also it signal will touch ground within 80.1 ft if mounted on 80ft tower
correct me if i am wrong
80ft distance at 80ft height is 45 degree that corresponds to 90 degree of vertical antenna angle.
