Mounting 5ghz Omni on side of mast?
If there was an omni on top of a pole and you wanted to mount another on the side below that did not require 360 coverage, would that cause adverse interfierence from reflections off the pole? If it is possible what would be the ideal distance to position it from the pole?
Thanks in advance :wink:
