MOUNTING AP-
Hi, am setting up a new ap and how and where do i mount the arrestor?And I need help to configure
Well, try with the manual…It is best way to learn, beleive me. I can help you if you ask questions…
For arrestor, just plug it between cable and connector on the card. From the side off the arrestor you have little screw where you should place wire. Connect that wire to the nearest grounding…
Cheers…
