Mounting RB433's to Wall
Does anyone know of a case other than the regular black ones from streakwave? They’ve managed to make this case almost impossible to mount on a wall other than using velcro or metal strap tape. The only other cases I can find are those huge expensive outdoor ones, which seem a bit over kill. I just want some cases that have mounting holes or some sort…
Looking for similar solution. Did you find anything?
Not the prettiest, but looks like a small cable box on the side of your house. You can screw it to the wall and then mount the rb433 inside. Its not too small and not too big for it.
http://www.wlanparts.com/product/ENCTEL/ENCLOSURE-9-IN-X-6-IN-x-31IN-INDOOROUTDOOR-1-PORT-GRAY.html
http://www.wlanparts.com/product/EZSNAP-5-35/PCB-Mount-Nylon66-48mm-standoff-35mm-hole-3M-adhesive-4-pack.html
You can back off the side case screws, put a paperclip behind the screw and wall mount it via the paper clip. Electrical spade connectors on the side screws would be another mounting method. RUn a wire between the two sides and hang it like a picture.
