And now for something a little different…
I have a few little Mikrotik routers that I’ve configured into a personal learning lab. I purchased a whiteboard that I discovered is “magnetic”, which just means it has a metal plate that allows you to attach magnet things to it.
I’m considering several ways to mount my routers to the board, including traditional screw mounts and velcro. I have come across magnet mount strips, which you can cut to size, that have adhesive on one side and magnets on the others. I assumed that these magnets would interfere with the operation of the electronics in the routers until I discovered that the mAP lite has a magnet in it to mount to metal surfaces.
So my question is: Is there any way to predict if these consumer magnet mount strip products will interfere with the electronics of the Mikrotik routers?
Product in question: https://www.3m.com/3M/en_US/company-us/all-3m-products/~/Scotch-Magnetic-Tape-0-5-in-x-4-ft-Black/?N=5002385+3293396931&rt=rud
Mikrotik routers: hAP, hAP lite, mAP 2n
