move a firewall rule from a script on a HotSpot
I’m running a HotSpot and I need to put move some firewall rules
each time Mikrotik reboot.
If I put on command line:
/ip firewall filter move [/ip firewall filter find comment=“prueba”] 0
… then it works perfectly.
BUT, if I make a script with this, in order to execute above code each
time Mikrotik reboot, seems like Miktotik doesn’t run script:
/system script add name=prueba
source={/ip firewall filter move [/ip firewall filter find comment=“prueba”] 0 }
and next, I test script with:
/system script run prueba
But nothing happens…! :frowning:
Can anobody helpme ?
Thanks !!! :smiley:
instead of /ip firewall filter move [/ip firewall filter find comment=“prueba”] 0 try something like /ip firewall filter move [/ip firewall filter find comment=“prueba”] [/ip firewall filter find comment=“comment_0_rule”]
Edgars
it works ! thank you!
