Hi I wonder if there is a smart way moving devices from main map to a newly created submap without having to “delete and recreate” them. IE Some drag and drop functionality somewhere or a property on the object that i have not yet discovered?
Please advice. What is the current best practise in this situation?
Select a device or devices on a map, copy, open new map, paste.
Thanks I didn’t think of that but:
This will create a new device making statistic readings / Historical Data of all device data not being there. Right?
What I am about to do now this “work around” will suffice. But there should be a move function as from dude’s standpoint it would be the same device an no historical data would be lost in the process.
Copy, Paste (as in ctrl-c ctrl-v doesn’t work in dude client windows.
Context menu on right mousebutton doesn’t show this as an alternative either. AM I missing something?
Yes. The buttons in the window work. But there probably is a bug or not assigned os standard shortcust to the button.
Thanks again for the suggestion it will suffice this time…
