I add a firewall rule to the Mikrotik:
add chain=input dst-port=161 protocol=udp action=accept
But the problem is that it goes to the end of the rules, so it is not working:
/ip firewall filter export
# dec/17/2015 16:12:07 by RouterOS 6.33.3
# software id = 9DRR-XSRN
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=\
ether1-gateway
Where is the good place to put it? on the top? How could I move with command line?
Thanks and regards.
