Move http-pap authenticated user to mac authentication
Hi All!
I’m currently using freeradius and I’m storing mac address in the database for those who successfully login using http-pap. After successful http-pap login they must use the mac auth instead of the username/password given to them. This can be done but the user will have to manually disconnect from the network and reconnect again and mac auth will be triggered.
But is it possible to tell mikrotik to change http-pap auth to mac auth after a successful http-pap auth? Or is there a CoA command I can use to tell mikrotik that the http-pap user must change to mac auth without the user needing to disconnect and reconnect to the network manually?
Thanks in advance.
