Hi, I have a 1100AHx2 (v5.14 ) that is being set up as a hotspot & running the internal user-man package.
I have a 2Gb micro SD card in the unit. I have formatted it and it appears to be running.
In the /store area the command I tried :
set 1 disk=micro-sdl
and it came back with `cannot change disk’
( 1 is the userman package as listed when I do a `print’ command )
Why ??
What is the procedure to kick the user-man over to the sd card instead of the internal system nand storage?
