Moving devices between network maps
Hi Guys
I have about 100 nodes on a single network map which is becoming very messy.
I have to separate the nodes into about 10 different maps. I do not want to remove them from the original map and then create them again in a new map, takes waaaay too long.
Is it possible to simple “move” them between maps?
You can copy device[devices] by ctrl+x, then go to the new map ctrl+v.
I just gave that a shot and nothing happened…i’m using v3.4, is that a problem?
Yes, I see only copy is allowed at version 3.6, and not cut[ctrl+x]. We will see what we can do.
Thanks, do you want me to upgrade to v3.6? Will I be able to export/import my config?
Export/import should work fine as on 3.4 as on 3.6.
As I told there is no move at 3.6, only copy the number of the device.
