Hello!, i’ve purchased a level 5 x86 licence, and i’ve installed it on a vmware machine for testing.
now my testing are ended, then i need to move this licence on a phisical server machine.
what i can do ??
thanks
what i can do ??
thanks
You can’t, the license is bound to the hard drive it was generated for. You should read up on the license before you purchase the next one.
send you vmware virtual machine to support, so they can check that it was really vmware =)
maybe they will give you another chance… =)
I Can Send you the vmware file, if you tell me where i can do it.
i also can give you remote access to this.
Thank You
send supout file to support mikrotik.com with description of the problem
mikrotik support had create me the replacement key
thank you!!
