I was adding clients for my company via IP to the dude and while testing auto discovery added most of them to a second map while testing. Now that I’ve worked out all of those kinks, I need to find a way to consolidate those two maps. Is there any way to transfer about 150 clients from one map to the other?
I figured out how to properly copy and paste between configs thanks anyways.
How do you do it?
ctrl-c to copy
ctrl-v to paste
If you are using windblows make a backup of the dude folder before performing major copy and pastes just to be safe.
