moving text along the link
hi, at the center of link between two devices, the text with link speed is displayed. can i move this text along the line? i have tightly placed devices on map, and the boxes of devices are big, because inside of them are displayed information about services, so one devices are located over this text and it is not visible. it would be nice if i will be able to move this text in another place on line. and, possibly, create not straight lines as well as lines drawn on your own, and lines which bend around devices, like the tracks on printed circuit board, he-he
I do not think that either of the things you want to do are possible “natively” in The Dude. There have been previous posts regarding making a link go around another device by creating a static object and using it as an intermediate point on the link, thereby creating a link with a corner in it.
This could also work for you to be able to adjust the position of the text. The text would still be in the centre of the link between the monitored device and the static object but you could move the static object along the link to adjust the position of the text.
May be worth a try.
