MPL TE RouterOS as PE/CE cisco as backbone lab
Hello again everyone,
I’d like to follow up on my MPLS learning and testing, first of all to tell you that I got the simulated and real scenarios depicted here: MPLS+ BGP VPLS now VLANs over the MPLS backbone
Devices: (all running MPLS)
2 Cisco 2821 (these are the LSR)
1 CCR1009 > LER
1 CRS125 > LER
1 RB2011 > LER
1 hEX PoE > LER connected to the cable modem
https://www.dropbox.com/s/bm19rwtot3k283g/Screenshot%202018-01-18%2011.07.45.png?dl=0
So, I’m testing TE Tunnels, all setup done as per these wikis
https://wiki.mikrotik.com/wiki/Manual:Simple_TE
https://wiki.mikrotik.com/wiki/Manual:TE_Tunnels_Example (incomplete, shame)
I’ve enabled TE on all of the routers including cisco on IFS and OSPF area 0
mpls traffic-eng tunnels
mpls label range 300000 399999
mpls label protocol ldp
 encapsulation mpls
 mpls ip
 mpls ip
 mpls traffic-eng router-id Loopback0
 mpls traffic-eng area 0
mpls ldp router-id Loopback0
I’ve setup the tunnel paths and interfaces on the RouterBOARDS and the paths one using CSPF and the other as strict path this TE tunnel I’m trying to bring up from the top most router (RB_CE) to the bottom most (RB_PE206), but the won’t come up and I’m getting CSPF path not found
11:23:25 route,ospf,debug Recalculating all OSPFv2 intra-area routes
11:23:25 route,ospf,debug Recalculating all inter-area routes
11:23:25 route,ospf,debug     summary-area=backbone
11:23:25 route,ospf,debug Recalculating AS-external routes
11:23:25 route,ospf,debug Installing an OSPF route in the main routing table
11:23:25 route,ospf,debug     prefix=10.255.255.206/32
11:23:32 route,ospf,debug CSPF: running
11:23:32 route,ospf,debug     destination=10.255.255.206
11:23:32 route,ospf,debug     constraints =hops=10.255.255.206 strict=false required-bandwidth=0.000000 priority=7
11:23:32 route,ospf,debug Find nonstrict constrained path
11:23:32 route,ospf,debug     from-routerID=10.255.255.105
11:23:32 route,ospf,debug     to-address=10.255.255.206
11:23:32 route,ospf,debug CSPF: path not found
11:23:32 route,ospf,debug SEND: Hello 192.168.206.122 -> 224.0.0.5 on ether2
11:23:32 route,ospf,debug,raw PACKET:
11:23:32 route,ospf,debug,raw     02 01 00 30 0A FF FF 69 00 00 00 00 C8 8A 00 00
11:23:32 route,ospf,debug,raw     00 00 00 00 00 00 00 00 FF FF FF FC 00 0A 02 01
11:23:32 route,ospf,debug,raw     00 00 00 28 C0 A8 CE 7A C0 A8 CE 79 0A FF FF 65
11:23:34 route,ospf,debug RECV: Hello <- 192.168.206.121 on ether2 (192.168.206.122)
11:23:34 route,ospf,debug,raw PACKET:
11:23:34 route,ospf,debug,raw     45 C0 00 44 CA 05 00 00 01 59 7F 74 C0 A8 CE 79
11:23:34 route,ospf,debug,raw     E0 00 00 05 02 01 00 30 0A FF FF 65 00 00 00 00
11:23:34 route,ospf,debug,raw     C8 8A 00 00 00 00 00 00 00 00 00 00 FF FF FF FC
11:23:34 route,ospf,debug,raw     00 0A 02 01 00 00 00 28 C0 A8 CE 7A C0 A8 CE 79
11:23:34 route,ospf,debug,raw     0A FF FF 69
11:23:34 route,ospf,debug   received options: E
If anyone can point me in the right direction or bring to my attention if I’m missing/not doing something?.
Many thanks.
