I am testing 2 rb411ah boards with R52N cards.
We used the wiki set-up for a MPLS / VPLS transparent bridge. We are using arc dual pole antennas and can achieve 100Mbps UDP test and 55Mbps TCP on the bench. We are very happy with the results using MPLS! We want to replace our current 22 Km WDS Bridge with this Bridge using MPLS and hopefully have simular results. I can’t seem to figure out how to transparently bridge and get my Vlans to pass through. I just want to use MPLS for the wireless bridge portion. Here is what we want to do, but I can’t seem to get my config right. I had created a vlan with a value of 2 on the ethernet and added it to the bridge on both boards… this didn’t work.
switch<=> vlan-id’s <===>eth1<===>>411ah<===>MPLS Wireless Bridge<===>411ah<===>eth1<===>vlan-id’s<=>switch
I’m not sure what to do. Thanks!
