I have this issue while I try to log on remotely on Mikrotik SXT…
I can login, but I can’t see the options in it. When I do login on telnet I have some problems too its too slow. As you can see I am running on 4.14 version of Mikrotik.
Should I upgrade the routeros? If I upgrade it, will the upgrade erase my config? I think no, but I want to make sure cause this is a link thats quite far away so I need to work it remotely…
Okay, I uploaded the npk package but I cannot reboot
I cannot reboot cause the SXT is so slow and when I type it doesn’t get the code. So… can a POWER on/off make the task, right? Or is there some other remote way to do it so… :/. I guess not
Normis, thank you very much for replies. Somehow when I logged to the device I was able to press System->reboot (the buttons) and at first it didn’t reboot, but after few retries it did. Now I have 5.7 RouterOs, the link is UP.
Thanks. I will have in mind the Netinstall for future problems like this!
