MPLS enabled router, simple queues not working
I have a router with MPLS enabled in ether1 (link), the client is in ether2 ..
Simple queue attached in ether2 interface…
with mpls on, simple queue doen´t work… mpls off, simple queue works..
in this case, with mpls on, i need to use TE tunels ?!
Here is a email that I got from MT when I asked the same question.
Queues can’t see packets with MPLS labels, only IP traffic. So if you enable MPLS
then packet are switched (not routed) and queues can’t see them.
Regards,
Maris
If you want to limit traffic it should be done before labels are added (ingress) or after labels are removed (egress router).
Nice Helpful!!! Thanks
