I have two sides A and B , both side are connected by two equal-cost paths running on OSPF.
OSPF making ECMP but when running MPLS I see mpls forwarding table make only one nest-hop, where i added both paths in LDP interface.
so mikrotik MPLS does not support ECMP ? or how i will fix the problem?
and also I faced one issue is, once one path goes down then mpls forwarding table does not update.
ECMP is not supported, MPLS will use only one path
Thanks @mrz for your replay.
I think it’s big problem for MPLS Mikrotik, wheres other routers (JUNIPER and CISCO) are supported ECMP LDP.
Does MikroTik have any plan to fix the problem?
