Do we know if there will be MPLS hardware forwarding on the new switches?
CRS354-48G-4S+2Q+
CRS354-48P-4S+2Q+
CRS305-1G-4S+IN
CRS309-1G-8S+PC
CRS328-4C-20S-4S+RM
CRS332-32S+RM
CRS312-4C+8XG
CRS354-48G-4S+2Q+
CRS354-48P-4S+2Q+
CRS305-1G-4S+IN
CRS309-1G-8S+PC
CRS328-4C-20S-4S+RM
CRS332-32S+RM
CRS312-4C+8XG
mikrotik is heavily investing into Marvell’s PRESTERA DX series SOCs. the crs326, the crs328 from the existing range use the 98DX3236A1, the beefier crs317 based on 98DX8216B0.
the just announced 20SFP version of crs328 has the very same cpu as the old 328.
https://origin-www.marvell.com/switching/assets/Prestera_98DX3336_pb.pdf
https://origin-www.marvell.com/switching/assets/Prestera_98DX8216_24-02_product_brief.pdf
just guessing, but i don’t think it is a coincidence that all new switches are from the CRS3xx range, and that could mean all of those are Marvell SOC based.
for example we have CRS332-32S+RM, which may be pretty much powered by the 98DX83xx SOC, at least the product brief of the SOC is just a perfect match for the 32S+ device.
https://www.marvell.com/documents/fitygdrdfcxvrimuvazb/
and now the “hard to swallow pills”:
with exception of the bold ones, no docs state HW MPLS capability. but i did not find them in any of the current Mikrotik range. and until now i wasn’t able to figure out what the new 40G equipped boxes are made of.
and i expect some untold tales to hide up their sleeves as i checked out the Prestera EX series SOC docs:
https://www.marvell.com/documents/mntcwjkmgpupqsargons/
this might be a root of a new breed of CRS4xx series with 100GE QSFP28s.
never the less, all the DX series SOCs do support vxLAN in hardware, something that is not exposed to RouterOS yet.
this might be a pretty good replacement for EoMPLS/VPLS in many cases, however.
so let’s hope Mikrotik gives us vxLAN soon.
I could be wrong, but I think HW MPLS is a given for the CRS305. What’s the point of a switch with so few ports? I just don’t see the use case if all it can do is switch. On the other hand, when you bring MPLS into the picture, it becomes more than a switch. It becomes a very fast, very cost-effective 10GbE router, assuming one is using MPLS in place of IP routing.
Example use-case: a site with three backhaul links (anyone had a chance to play with a pair of BridgeWave Flex4G-10000’s yet?
). Connect the 4th port to a CCR for access.
Doing MPLS/VPLS and VXLAN in Hardware on switches is a HUGE opportunity for Mikrotik to carve out a niche.
I know if this was supported, I wouldn’t be buying 1 or 2 switches per year, it would be hundreds if not thousands of switches per year.
Couldn’t agree with you more…nobody has VXLAN in anything with an ASIC that’s under a few thousand that i’ve seen.
