MPLS Labels in Traceroute
By doing a traceroute to Amazon.com, I noticed that there are some MPLS Labels in the Status column after entering the Amazon network (52.93.37.93). My question is: how is this done, and can I do the same in my network? Here is the traceroute I get:
Why would you want to? What is your use case?
Curiosity, and testing.
They route Layer III traffic over VPLS tunnels. If you do the same, you will also see “cool” MPLS labels on your traceroutes (if the OS supports it, of course). Most commonly in the MT world is to use VPLS for PPPoE (encapsulated) traffic, and therefore, the labels aren’t visible.
