Hi! What is the AFI conception of the MPLS LDP configuration? It is for LDPv6 or for 6PE?
AFI in LDP configuration allows to specify on which address-family control plane will be working.
Thanks mrz! What if I don’t specify the AFI and the backbone is dual stacked with IGP?
Then it should work on both AFIs.
