MPLS MTU Bug or me?
Anyone find that when you set the MPLS interfaces MTU to “all” and set a value for example 1508 that it doesnt work?
If I leave just one entry to nothing but “all”, that the resulting MTU is much lower than what you set it to?
Only way I can get the desired MTU on an MPLS interface is to specify each interface manually and set the MTU to 1508.
