MPLS over SNMP
Hi
This is the first time i pose on a forum so hope it won’t be the last .
I’m in middle of my Graduation Project and if i dont find the solution for my problem i will be forced to cancel it so please i need HELP .
I’m working on a company backbone and i’m developping an app that extract all informations from routers in order to virtualize it .
I’m using SNMP and so far everything was OK , until it comes to MPLS LSP paths and with this oid “1.3.6.1.4.1.2636.3.2.3.1.17” i should get all paths .
I got only the primary paths !
I need to get also the secondary path of every LSP . I’m working on a MX480 Juniper Router .
Hopefully waiting for an answer .
