MPLS over WiFi
Hello to all,
I want to do this:
LAN1=={port 4/5 hex S1 port1}====[port1 client AP]---- wifi----[AP port1]===={port1 hex S2 port 4/5}==LAN2
---- wifi link
=== ethernet link
I want on LAN1 and LAN2 to use port 4(vpls1) and port 5(vpls2) with 2 different VPLS, So vpls1 tunnel on LAN1 can reach vpls1 on LAN2, and similar on vpls2. At L2, seems to be
OK as I can access any Mikrotik device if I plug my laptop in hex S1,2 I can access any other mikrotik mac winbox. The same result if I use arp ping. So it seems that is a routing problem?
