mpls package, do I need it ?
Hi all,
I’ve disabled a few packages that I don’t use: wireless, hotspot and ipv6, but I don’t know if I can disabled mpls, don’t want to break my config.
I use my route for:
  1. Routing
  2. PCC Load balancing + failover
  3. Firewall
  4. VPN
  5. Proxy
  6. DHCP
  7. Queues
My question is, can I disable this package ? In winbox, in MPLS there is no rule added (enabled).
If you don’t need MPLS/VPLS for anything, then yes, you can remove it.
IMO, it really doesn’t hurt anything to leave all the default packages. I used to be a bit of a nazi about removing unused packages, but with 100’s of devices, it got to be a little annoying, especially when it was time to actually implement MPLS on my network. I now use the -all packages, adding the ntp package when/where necessary.
Good luck!
Thank you
