The following link which shows a MPLS transparent bridge was working on my earlier version 4.3 but since upgrading it to v5.5 this has stopped working. any idea why???
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS
Could you describe in more detail what is not working? Perform some debugging and narrow it down to a certain issue.
PC —> AP1 <========> AP2 ----->PC2
10.10.1.99(PC) -----> 172.168.0.1(WLAN1) <==========> 172.168.0.2(WLAN1) ------> 10.10.1.88(PC)
the AP1 and AP2 are connected wireless using RB711.
after the MPLS configuration i can ping both the AP’s wirlessly… but PC1 and PC2 still cannot see each other.
it was working fine before i upgraded the version.
-sid
transparent bridging using wds, eoip or vpls is NOT necessary any more with ROuterOS 5.5.
just use bridge-mode: enabled on the AP and “station-bridge” on the station.
manually put the wlna-interfaces in your bridge.
tried… did not work.
the MPLS link did work now…
bridge…bridge…bridge…!!!
works ![]()
