MPLS Tunnel aggregation (stacking labels)
Hi
I am asking myself if there is any posibility of aggregate mpls tunnels in the Mirkotik implementation. My idea is explained in the image attached.
I have 2 PC’s sending traffic to other(GW) using a MPLS network. I have tested establishing 2 different tunnels from each PC to the gateway and works well, but I think that is not quite efficient, since with statistical traffic (ej data traffic), TE tunnel capacity is not well exploited.
For this reason I would like aggregate the two tunnels in one in these links where both tunnels share path. I was thinking in make a “double” TE tunnel where the stack label had 2 levels. Something like this:
|–10–|–10–|------|–10–|–10–|----|–45–|
|–45–|–20–|------|–45–|–20–|
(M symbol is the Mikrotik equipment)
Where the TE tunnel from PC2 to gateway had the label 45 and after the first wireless link, it was encapsulated inside other Tunnel with the label 10. Also addtional traffic would be injected in this tunnel from PC1 with the label 20.
There is some way to implement this?Maybe could I use static/manual label binding?
Is a non-sense question?
Any idea will be welcomed :slight_smile:
Kind regards
