lcm
1
Hi guys,
i need some help here, this is my scenario:
Rt1 → Rt2 → Rt3 → Rt4 → Rt5
Rt1
RouterOS 5.26
Rb1100AHx2
Rt2 to Rt5
RouterOS 5.26
Rb1200
They are running OSPF + MPLS with a /29 between each router.
vpls tunel with LDP
The problem:
I can estabilish the vpls and Ping from Rt1 to Rt2,3,4 the tunel with Rt1-Rt5 is estabilished but cant ping each other.
Ldp interfaces have been added, mpls interface MTU is 1500 for all.
some clues?
More info:
i did a sniffer and attached the image. it seens cant find the interface (unknown)
It isn’t clear which IPs you have assigned to the VPLS interfaces or what the routing table looks like on R1 & R5.
lcm
4
ok, i’m sorry about that, i’ll try to be clear:
vpls from Router 1 to Router2:
r1 vpls ip-192.168.0.1
r2 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router3:
r3 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router4:
r4 vpls ip-192.168.0.2
Status running.
ping OK
vpls from Router 1 to Router5:
r5 vpls ip-192.168.0.2
Status running.
ping NOT OK
With default ping size.
i can ping from outside the vpls
Does it show running at both ends - R1 & R5? (I ask because it is possible to get one end showing running and the other end not…)
Any firewall differences on R5?
You say:
But I thing you should use 1526 for mpls interface MTU when use vpls.
/mpls interface
set 0 interface=all mpls-mtu=1526
lcm
7
thanks for the answer.
yes, running on both ends.
no firewall at all.
lcm
8
yes i know i should, but i have some mtu problema with wireless devices. so if i keep the mtu 1500 the RB must fragment the packet, right?
If MTU is too large and next header is IP
Then generate “ICMP Need Fragment error”
Else silently discard packet
