Hey i’ve been working on getting mpls/vpls to work with a vlan for use with public ip customers later. This is the code from a test network that I setup. In the real network the links between the routers will be ubiquiti wireless backhauls and there will be unifi routers. I was hoping to see if someone could look over my code and see if anything looks weird it’s working in the test environment but I need to make sure it will be working when I role it out. I was wondering about my mtu i have it set to 1508 (not sure if that’s right) and I guess i’ll have to change the mtu on the switch and wireless backhaul too? For something like this I probably wont need to change anything to proxy-arp right? I just had a lot of trouble figuring this out for some reason so wanted to double check it.
thanks
Edge router
add name=Managment
add name=bridge2
add fast-forward=no name=vpls protocol-mode=none
set [ find default-name=ether1 ] arp=proxy-arp comment=Internet mtu=1508 \
speed=100Mbps
set [ find default-name=ether2 ] comment=Jlkz mtu=1508 speed=100Mbps
set [ find default-name=ether3 ] comment=Elroy speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
/interface vpls
add advertised-l2mtu=1508 disabled=no l2mtu=1508 mac-address=\
02:FE:FF:13:D6:48 mtu=1508 name=vpls.jlkz remote-peer=192.168.255.101 \
vpls-id=1:1
02:FE:FF:13:D6:48 mtu=1508 name=vpls.sonya remote-peer=192.168.255.103 \
vpls-id=3:3
/interface vlan
add interface=ether1 mtu=1508 name=vlan140 vlan-id=140
add name=dhcp ranges=10.20.2.50-10.20.3.254
add name=pool1 ranges=192.168.10.10-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge2 name=DHCP
add address-pool=pool1 disabled=no interface=vpls name=test
/routing bgp instance
set default as=27
/routing ospf instance
set [ find default=yes ] distribute-default=always-as-type-1 mpls-te-area=\
backbone mpls-te-router-id=Managment router-id=192.168.255.100
add bridge=bridge2 hw=no interface=ether6
add bridge=bridge2 hw=no interface=ether7
add bridge=bridge2 hw=no interface=ether8
add bridge=bridge2 hw=no interface=ether9
add bridge=vpls interface=vlan140
add bridge=vpls interface=vpls.jlkz
add bridge=vpls interface=vpls.sonya
add address=192.168.255.100 interface=Managment network=192.168.255.100
add address=172.20.0.1/29 comment=jlkz interface=ether2 network=172.20.0.0
add address=10.0.0.45/23 interface=ether1 network=10.0.0.0
add address=10.20.2.1/23 interface=bridge2 network=10.20.2.0
add address=172.20.0.9/29 comment=Elroy interface=ether3 network=172.20.0.8
add address=192.168.10.1/24 interface=vlan140 network=192.168.10.0
add address=10.20.2.0/23 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.2.1
add address=192.168.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.10.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=10.20.2.0/23 list=routers
add address=172.20.0.0/24 list=routers
add address=10.20.8.0/23 list=routers
add address=10.20.4.0/23 list=routers
add address=192.168.10.0/24 list=routers
add address=10.20.6.0/23 list=routers
add address=10.20.10.0/23 list=routers
add address=10.20.12.0/23 list=routers
add action=masquerade chain=srcnat src-address-list=routers
add distance=1 gateway=10.0.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=192.168.255.100 transport-address=\
192.168.255.100
/mpls ldp interface
add interface=ether2
/routing bgp network
add network=10.20.2.0/23 synchronize=no
add disabled=yes network=192.168.10.0/24 synchronize=no
/routing bgp peer
add in-filter=ospf-in name=Jlkz out-filter=ospf-out remote-address=\
192.168.255.101 remote-as=27 route-reflect=yes ttl=default update-source=\
Managment
add in-filter=ospf-in name=Elroy out-filter=ospf-out remote-address=\
192.168.255.102 remote-as=27 route-reflect=yes ttl=default update-source=\
Managment
/routing ospf interface
add cost=2 interface=ether2 network-type=point-to-point
add cost=2 interface=ether3 network-type=point-to-point
/routing ospf network
add area=backbone network=192.168.255.100/32
add area=backbone comment=jlkz network=172.20.0.0/29
add area=backbone comment=Elroy network=172.20.0.8/29
/system clock
set time-zone-name=America/New_York
/system identity
set name=edge2
/system routerboard settings
set silent-boot=no
jlkz router
add name=Managment
add name=bridge4
set [ find default-name=ether1 ] comment=Edge mtu=1508 speed=100Mbps
set [ find default-name=ether2 ] comment=Sonya mtu=1508 speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
/interface vpls
02:40:35:FB:F5:F3 mtu=1508 name=vpls.edge remote-peer=192.168.255.100 \
vpls-id=1:1
/interface vlan
add interface=bridge4 mtu=1508 name=vlan140 vlan-id=140
add interface=bridge4 name=vlan600 vlan-id=600
/ip hotspot profile
add hotspot-address=10.21.4.1 login-by=mac,http-chap,http-pap \
mac-auth-password=visp name=hsprof1 use-radius=yes
/ip hotspot
add disabled=no idle-timeout=50m interface=vlan600 name=hotspot1 profile=\
hsprof1
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=no on-logout="/ip hotspot host remove \
[find where address=\94\$address\94 and !authorized and !bypassed] "
add name=DHCP_Pool ranges=10.20.4.50-10.20.5.254
add name=hs-pool-19 ranges=10.21.4.50-10.21.5.254
add address-pool=DHCP_Pool disabled=no interface=bridge4 name=DHCP
add address-pool=hs-pool-19 disabled=no interface=vlan600 lease-time=1h name=\
dhcp1
/queue type
set 9 kind=red
set default as=27
set [ find default=yes ] mpls-te-area=backbone mpls-te-router-id=Managment \
router-id=192.168.255.101
add bridge=bridge4 hw=no interface=ether7
add bridge=bridge4 hw=no interface=ether8
add bridge=bridge4 hw=no interface=ether6
add bridge=vpls interface=vpls.edge
add bridge=vpls disabled=yes interface=ether1
add address=172.20.0.2/29 comment=Edge interface=ether1 network=172.20.0.0
add address=192.168.255.101 interface=Managment network=192.168.255.101
add address=10.20.4.1/23 interface=bridge4 network=10.20.4.0
add address=172.20.0.17/29 comment=Sonya interface=ether2 network=172.20.0.16
add address=10.21.4.1/23 interface=vlan600 network=10.21.4.0
add address=10.20.4.0/23 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.4.1
add address=10.21.4.0/23 comment="hotspot network" gateway=10.21.4.1
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.21.4.0/23
/ip hotspot ip-binding
add address=10.20.4.0/23 type=bypassed
add address=0.0.0.0/0 type=blocked
/ip hotspot user
add name=admin password=????
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept disabled=no !dst-address !dst-address-list dst-host=\
ocsp.godaddy.com !dst-port !protocol !src-address !src-address-list
secure7.userservices.net !dst-port !protocol !src-address \
!src-address-list
wlogin.userservices.net !dst-port !protocol !src-address \
!src-address-list
/ip service
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=192.168.255.101 transport-address=\
192.168.255.101
/mpls ldp interface
/radius
/radius incoming
set accept=yes
add network=10.20.4.0/23 synchronize=no
/routing bgp peer
add name=edge remote-address=192.168.255.100 remote-as=27 route-reflect=yes \
ttl=default update-source=Managment
add name=Sonya remote-address=192.168.255.103 remote-as=27 route-reflect=yes \
add cost=2 interface=ether1 network-type=point-to-point
add area=backbone network=192.168.255.101/32
add area=backbone network=172.20.0.0/29
add area=backbone network=172.20.0.16/29
/system clock
/system identity
set name=Jlkz
/system ntp client
set enabled=yes primary-ntp=209.51.161.238 secondary-ntp=50.129.194.189
set silent-boot=no
sonya router
add name=Managment
add name=bridge8
set [ find default-name=ether1 ] comment=jlkz mtu=1508 speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] comment="To josh c" speed=100Mbps
/interface vpls
02:18:A9:AC:C6:C4 mtu=1508 name=vpls.edge remote-peer=192.168.255.100 \
vpls-id=3:3
/interface vlan
add interface=bridge8 mtu=1508 name=vlan140 vlan-id=140
add name=DHCP_Pool ranges=10.20.8.50-10.20.9.254
add address-pool=DHCP_Pool disabled=no interface=bridge8 name=DHCP
set default as=27
set [ find default=yes ] router-id=192.168.255.103
add bridge=bridge8 hw=no interface=ether9
add bridge=bridge8 hw=no interface=ether8
add bridge=bridge8 hw=no interface=ether7
add bridge=bridge8 hw=no interface=ether6
add address=10.20.8.1/23 interface=bridge8 network=10.20.8.0
add address=192.168.255.103 interface=Managment network=192.168.255.103
add address=172.20.0.18/29 comment=jlkz interface=ether1 network=172.20.0.16
add address=172.20.0.34/29 comment="Josh C" interface=ether3 network=\
172.20.0.32
add address=10.20.8.0/23 dns-server=8.8.8.8,8.8.4.4 gateway=10.20.8.1
/ip service
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=192.168.255.103 transport-address=\
192.168.255.103
/mpls ldp interface
add network=10.20.8.0/23 synchronize=no
/routing bgp peer
add name=jlkz remote-address=192.168.255.101 remote-as=27 route-reflect=yes \
add in-filter=ospf-in name=joshc out-filter=ospf-out remote-address=\
192.168.255.105 remote-as=27 route-reflect=yes ttl=default update-source=\
Managment
add cost=3 interface=ether3 network-type=point-to-point
add area=backbone network=192.168.255.103/32
add area=backbone comment=jlkz network=172.20.0.16/29
add area=backbone comment="Josh C" network=172.20.0.32/29
/system clock
/system identity
set name=Sonya
set silent-boot=no
