I am trying to connect using the iot package to an mqtt broker but I can’ t manage to connect using SSL.
My ssl certificate is terminated to an HAProxy and other mqtt clients connect fine even from windows 7 outdated using older cipher but the mikrotik won’t connect. I get SSL Handshake failure to the haproxy log and connection failed to the mikrotik.
I wonder whether I need to download manually a certificate and choose it in the broker/certificate but of course that would be an issue because if I have it installed in thousands mikrotiks the moment I will need to change the certificate in my server I would need to modify all mikrotiks.
If I connect directly to the broker without ssl to 1883 it works fine.
Some other suggestions would also be to be able to disable a broker and to disconnect/connect from winbox not only cli.
